Need some advice
rokar
Ok I need a new power supply for my server:
Tyan Thunder K8SR, 2x AMD Opteron 270, 4GB Micron DDR 400 ECC
areca ARC-1160ML2
1x WD 640gig system drvie
4x WD RE3 1TB
4x WD RE2 1TB
4x WD RE2 500gig (maybe)
6+ 120mm case fans
Was looking at this. Currently have an enermax, been running 24/7 for the past 3+ years. Thanks for the help!
Get it while it's still cheap. You will feel sorry (like I do now) if you don't order it and the price jumps a few days later. Read my last post on my own thread "Got an issue here".
That Enermax PSU you chose is an excellent choice for a PSU.
With that many drives and CPUs, I would not go any less than a 750W PSU with a combined amperage of 60A on the +12V rail. So that Enermax is definitely more than enough.
