Need some advice...
nsyrax
Alright, let me get the details out of the way. Here are my computer specs:
AMD Athlon 64 X2 2.2ghz
Asus A8N-SLI Premium mobo
Windows Vista Home Premium 64bit
3 gigs of RAM
Radeon X1550 w/256megs of RAM
I want to upgrade my video card and am wanting to keep it under $400. Here is what I'm looking at:
1x http://www.newegg.com/Product/Product.aspx?Item=N82E16814143080
2x (dual SLI) http://www.newegg.com/Product/Product.aspx?Item=N82E16814150252
What would be the best way to go, or would you suggest something else?
Have you looked at SLI 9600s? Tad cheaper and still very good at playing games.
3 gigs of RAM
I would go with 8800GT SLI out of those two choices, but only if you are sure that if you got one 8800 GTX that you wouldn't get a second to pair with it down the road.
