need some advice with case setup
toolskizm
So I have that case, whatever it's called (I forgot...been a long time since I bought it). I was wondering if you guys could help me out on airflow and heat. I plan to get rid of the two IDE's that are in there. I'll replace the dvd IDE with a Samsung SATA and that Seagate IDE with a Seagate SATA. Now, I have three fans in it right now because that's all I can fit. I have another fan I bought, but can't use right now. I was thinking of buying this...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817995001
either that one, or the 4 slot. I'm not sure which I'd be better off going with considering heat. Noise is not a concern, the thing sounds like an airplane and always has. So anyway, I was thinking of getting the back plane so that way I could move 4 or 5 hard drives into the 5.25 bays, then I could get another fan in the case. Now, should I get all the fans facing the front (toward the HDDs) or what? Any suggestions regarding..well anything I can do which you think would be better for the case let me know. I'm interested in any input. (and yeah, the cable management isn't great...with the PSU it's tough because of the cables that come with it...I like thermaltake's wires better)
if interested:
hard drives in order from top to bottom
1 x Seagate 200GB IDE
1 x Seagate 200GB SATA
1 x Seagate 300GB SATA
2 x Seagate 750GB SATA
will very soon be (within next week or so)
1 x Seagate 80GB SATA
2 x Seagate 300GB SATA
just something to keep in mind considering back plane, heat, fan placement, etc.
this is a server PC if it isn't noticeable
You may want to mod two Antec Big Boy 200mm fans on the bottom (intake) and and top (exhaust)
120mm vs 200mm
Yeah, that would be nice if I could fit the 200mm fan, but I'd have to cut huge holes in the case. Seems like it would make more since to just buy another case, which I would like to avoid doing. Thanks for the input though.
