Ingonuts13
- Jun 9, 2003
I am looking to W/C my entire set-up to get the temps down and get a little more performance out of my system. I am not opposed to Retail solutions (i.e. Koolance) but I doubt the performance would be as good as a DIY job. My main concern is cleanliness, my case right now is very clean and I really wish to keep it that way. Also, this will be my first W/C solution so be gentle. I know to leak test and all that stuff and yes, I have done a
lot of homework on it.
My Specs:
P4 3.0C
DFI875B
BFG6800Ultra
Lian-Li pc75
Here is some parts I've been looking at:
CPU: Considering the Swiftech 6002. Seems to be the way to go here.
CHIPSET: Do I really need this? My DFI has passive cooling on it so I am guessing it would be a good idea to use w/c on it. Also, what Chipset W/C solution would fit my boards chipset?
GPU:6800 Waterblock Seems like the only way to go here.
PUMP: An inline solution like the Swiftech 650 seems the way to go here.
RADIATOR: Black Ice Extreme? Not sure here. From what I have been reading, a shroud is a must. Also, any reason to go DUAL RADIATOR?
RESERVOIR: I love the look of the Innovatek Tank-o-Matic but the inlets are only 5/8 I believe. (is this bad) Do I even need a Res?
TUBING: Going with Tygon, I hear its the best.
COOLING LIQUID: I read about this stuff somewhere that is non-conductive and replaces water in the system. I am freaked out about getting a leak and frying everything, so I am really considering this stuff. ANY THOUGHTS?
Also, what would be the best way to have the entire system set up?
Pump>RAD>CPU>GPU>CHIPSET>RES? or should I consider Dual RAD with
PUMP>RAD>CPU>RAD>GPU>CHIPSET>Res?
Some input from the Pro's would be great here if anyone has any suggestions.
Thanks A bunch
My Specs:
P4 3.0C
DFI875B
BFG6800Ultra
Lian-Li pc75
Thanks A bunch
