My stuff is running really hot since I SLI'd with 8800GTXs.
I'm thinking of WC my CPU for starters.
I'm a noob's noob with this so I think the Nautilus 500 would be the way to go???
I have an ASUS P5N32-E SLI board, will I need to put some kind of fan on/near the NB???
The Nautilus will replace an ArcticCooling Freezer Pro 7.
I know the heat is primarily from the two big GPU's, but this seems to be a good solution to reduce some of the heat.
I have several 80mm Panaflo fans and a 120mm fan on the side window.
Any one who uses the Nautilus set-up with pros/cons is appreciated.
