Hey guys!
Looking for Air Flow fans. I will need 2 120mm on top of the case and 2 120mm at the side. I was looking at the Corsair ML series, and I was about to buy them because they are suppose to be quieter and they come with LED lights. I later found out about buying cheaper Noctua and then buying a separate LED kit.
For Noctua, I am looking at NF-S12B redux-1200 and NF-S12A FLX. My question is the premium for the S12A for the rubber corners worth it? S12A is about $5 more compared to the S12B redux. These 2 fans are basically the same minus the noise dampener material that come with the S12A FLX.
My computer runs 24/7, and fans are full speed at summer during the day. Coolermaster fans keep dying right after the warranty so I need to switch brands, hehe.
Also, any suggestions or notes on LED kits?
