need some advice on overclocking my FSB
Layer01
ok so i'm trying to get my head around Overclocking in general, i think i "get" it now but i just want to double check.
here is my setup:
qx6700
Gigabyte GA-P35-DQ6
Ultra 120 extreme
8gb ddr2 800
8800GTX
so far i've just pushed up the multiplier to 12 with the FSB at 266 giving me 3.2Ghz
But I see all over the place that you should try and keep your memory and FSB on a 1:1 ratio
does that mean i would have to set my FSB at 400?
I assume i would lower the multiplier because that would be really pushing it right?
so would i be right in thinking that i should set my FSB to 400 and lower my multiplier to 8? giving me 3.2Ghz again.. but with a ratio of 1:1
Or would this just fry my cpu? :p
I would leave your multi alone and up the fsb on the stock multi.
Leaving your memory divider to 1:1
if i type in 400 for the fsb i get this readout in the bios:
System Memory Multiplier (SPD) [AUTO]
Memory Frequency(Mhz) 800 1200
if i set the FSB back to 266, the 1200 reads 800.
what does this number mean? seems high whatever it is..
to see my ram specs go to http://www.gskill.com/indexen.html
Products
Model Name : F2-8000CL5D-4GBPQ
here are the details copied from that page.
Capacity 4GB (2GB x 2)
Speed 1000MHz DDR2 (PC2-8000)
CAS Latency CL 5-5-5-15
Test Voltage 2.0~2.1 Volts
PCB 6 Layers PCB
Registered/Unbuffered Unbuffered
Error Checking Non-ECC
Type 240-pin DIMM
so you're saying i should up my fsb to 400 and lower my multiplier to compensate?
well i just stepped up my FSB to 333 and turned the mult down to 8 and the system failed to POST.
not really sure how i can get a 1:1 ratio when i can't up the fsb..but then i'm a big oc noob, any advice?
anyone?
do i need to provide some more info or is my question just really dumb lol :p
