Need Some Advice on Kits
Yeah Im goin the kit route. I dont wanna mess my comp up to bad with my first watercooling experience. My question is this:
I wanna get a good kit and so far Im looking at this: "Thermaltake AquariusII Liquid Cooling System " because I know for a fact that it will fit my XaserIII, but I wanna make sure that the path I've taken is a wise one.
Thanks
I'd say you would be better off with a swiftech 8501 kit. At he least you can use the block, and pump with any upgrade radiators, and filling gear. It costs about $50-60 more though.
Almost all reviews of the Aquarius don't recommend it for serious cooling. If you want simplicity with good performance, go with the Koolance Exos. If you want hard core cooling, go with Swiftech, D-Tec Customs or Danger Den.
