Need some advice.....new media encoding setup
DMarti
Well I sold all my Dual P3 Server and Firewalls on egay and I sold off my Opteron 170 setup on the forums.
I will build this as a no-holds-barred media ripping/compressing work station since that is what I have been doing mostly of late using FAIRUSE (actualy uses 2 processors / cores ) and dvdfab and dvd shrink(Netflix is a bad thing )I figured i'd get through with this as my media ripping phase & double as a home server later until I can save up for a Core 2 Duo setup when I see more of a use for 2 cores and i get the $$. Anywho here's the specs:
SuperMicro X6DAL-B2 Mobo
http://www.supermicro.com/products/m...5/X6DAL-B2.cfm
Dual 3.4GHz Xeon Noconas (EMT64, 1 meg L2)
ASUS6600 PCIe
Addonics 64-bit PCI-X 4-port SATA-II RAID card
http://www.addonics.com/products/hos.../adsa3gx4r.asp
4GB DDR2 Ram
2XWD500GBSATAII Drives
2XSeagate 320GB SATAII 16MB cache
1XMaxtor 300GB SATA 16MB Cahe
3XWD180GB IDE
Lite-On Dual Layer IDE DVDRW
SILVERSTONE ST85ZF PSU
Given what I have, what do you think would be the optimal setup for my drives? Kind of a Raid n00b but I am tempted in getting a third drive of the Seagate 320GB (~$94@newegg) and setup a Raid 0 array for boot and working the ripping / encoding. Then use the 2 500GB's and 3 180GB for storage. No real mission critical data here, have that all backed up externally
I Have a 150GB Raptor and my 7900GT set aside for my impending Core 2 Duo Build, but am open to suggestions.
Researching this a bit more I see that this card can attain speeds of throughput up to 200 Mbytes/sec when 4 drives are striped together?( I am guessing this is RAID 0). Kind of expensive and hard to beleive but those speeds seem amazing Perhaps this is with Raptors they attained this speed?
Looking for you all to chime in with advice, thanks!
