Let me first apologize, cause this thread might get a little long, but please bare with me. I have no experience with water cooling, but i tried to soak up as much as I could from the stickies. However, I still have a few unanswered questions. Ive included a diagram of some setups I was thinking about to help illustrate ( i have too much time on my hands... lol
1. I believe I read somewhere that the reservoir had to be the highest point in the system loop, if thats true that would make options 3 and 4 in the diagram worthless, however these would provide the most cooling power due to the larger radiators. So is it ok for the radiator to be the highest point?
2. If the radiator can be the highest point, which would be a better setup, 3 or 4. It seems most people choose setup 4 as far as which way to pull air through the radiator. But my concern is the air being blown into the case. Having no experience with water cooling, I dont know how hot the air coming off the radiator is; is it enough to significantly raise ambient temp inside case, and by significant, I mean by more than 5 degrees celcius?
3. If the top mount rad's wont work, and I am forced to go with option 1 or 2, will a single 120mm fan radiator still be enough cooling for lets say an A64 FX-57 and an nforce 4 sli chipset?
4. Would I see any significant difference in temps between a single 5 1/4" bay reservoir, and a dual setup? The differences being how long till the water reaches its "equilibrium" correct? If at most Im only on my computer for 5 hours, would it be worth it to get the dual bay setup?
5. And lastly, could anyone give me some educated guesses as to what temps I would see with the two different radiators in the diagrams ( Black Ice Xtreme and Black Ice Xtreme II). Im shooting for high 20's idle and low 30's load; is that possible with any of the setups and hardware listed below? A lot of the posts in the "show your rig" thread have people posting up temps as well, and everyone Ive seen have the same temps I get now with AIR cooling or worse, which kind of turns me off to watercooling. I was really hoping to get much lower temps than my Swiftech MCX-462 HS and Vantec 92mm Tornado on Athlon xp 3200 (37idle 42 load).
Copper TDX Block for Athlon64
ASUS A8N MAZE4 Chipset Block
12V DD-D5 Pump
Black Ice Xtreme II Radiator
Tygon 3603 Tubing 1/2" ID 3/4" OD
Danger Den Dual 5 1/4" Bay Reservoir (or Single)
Thanks for reading.
12V DD-D5 Pump
Thanks for reading.
