Need some Access VBA Help
Florida Doc
Hello,
I'm trying to write a subroutine that will update the usermodified field when a person clicks the save user button on a form. However, I keep getting the error: "Object variable or With block variable not set".
The table name is Users, the field I want to modify is UserModified, the field containing the username in the table is Username, and the form has a control called Username.
Here's my code:
Private Sub SaveChanges_Click()
On Error GoTo Err_SaveChanges_Click
DoCmd.DoMenuItem acFormBar, acRecordsMenu, acSaveRecord, , acMenuVer70
DoCmd.DoMenuItem acFormBar, acRecordsMenu, 5, , acMenuVer70
Dim mySQL As String
Dim con As Object
con = Application.CurrentProject.Connection
MsgBox "Username to modify is " & Me![Username]
mySQL = "UPDATE [Users] SET [Users].[UserModified] =" & Now()
mySQL = mySQL & " WHERE [Users].[Username]=" & Me![Username]
MsgBox "SQL command is:" & mySQL
DoCmd.SetWarnings True
DoCmd.RunSQL mySQL
'Close the connection
Set con = Nothing
Exit_SaveChanges_Click:
Exit Sub
Err_SaveChanges_Click:
MsgBox Err.Description
Resume Exit_SaveChanges_Click
Any idea what's wrong?
Thanks!!!
well, you aren't actually using the 'con' variable anywhere.
you might want to think about creating an actual stored update query and calling that on a button press
If you still want to use VBA here is an update to your sql syntax for the first line.
mySQL = "UPDATE [Users] SET [Users].[UserModified] =# " & Now() & " #"
With access you need to put the date inside # # if your field in the table is defined as a date.
