I got a new case a few days ago, an Antec 902 v3. Also bought a Corsair H50 for my Phenom 965BE. Motherboard is an Asus M4A78L-M and memory is 4GB of G.Skill DDR2-800.
So far the limited overclocking I've done has all been in software, with AMD OverDrive. Auto Clock got me to an HT clock of 203MHz, 18.5 multiplier, yielding 3755.5MHz with no voltage increases.
Since then, I've been running with the multiplier at 18x (3.6GHz). Haven't run Prime95 or anything yet but after all kinds of gaming my temps are still sub-40c.
Ideally I'd like to get this thing stable at 3.8GHz, I think that's my goal. I have a few questions about how I should do this, mainly relating to voltage changes.
Rather arbitrarily, I'm thinking I'll end up with an HT clock of 205MHz with an 18.5x multiplier, putting me just below 3.8GHz. Current voltages are 1.40V on the CPU, 1.10V on the NB, and 1.89V on the DDR2-800 memory (rated for 1.80-1.90V).
The part I'm not sure about is whether people generally bump up all three of those voltages as you increase your overclock. From what I understand, increasing your multiplier doesn't put as much strain on your motherboard and memory, but you don't get the RAM speed increase. So I assume if I'm raising my multiplier by 1.5 and my HT clock by only 5MHz, most of the extra voltage should go to the CPU.
