Need some 550-750W recommendations
techboydino
Looking for some assistance...
Looking for a PSU to fit a recent build. Hoping to find something on the smaller size but SFX not needed.
Req's are as follows:
Fully Modular (custom cables will be made)
Gold or Platinum Rated
550-750W
As quiet as possible (does not have to be passive, quiet fan is fine)
Around $125
Looking at the
Seasonic 660 platinum
Evga 650 G2 - (perfect fit except caps/filters in mobo cable is really annoying)
Antec Edge 650
Corsair ???
Open to suggestions. Thanks.
I vote for the Seasonic. Mine works beautifully, even in a mini itx case with essentially no airflow.
thx, i was leaning that way but only held up for now due to price. many said that coupons took it below $100 in the past but i need to get things moving. i might have to bite the bullet soon. which one do you have?
Oops, looks like I have a SS-520FL2. Still powers my rig with zero issues.
The new Corsair RM 650i (with all Japanese capacitors) and a 90% power efficiency is what I'd go for.
Great option, right in line (pricewise) with the Seasonic 660. I may just pick one and bite the bullet. I've had Seasonic in the past and had no issues. But I like the added features in the Corsair. Amazon has the Corsair prime for $130. Thanks for the info.
