Need some 3.2C voltage suggestions
What voltage would you recomend for a 3.2C running at 3.8 GHz? Auto works up to 3.61 only on this system and I'm not able to reinstall my cpu back into my P4C to find out what worked previously.
Thanks,
DC
1.65 or 1.7 maximum should be maximum. Start out at a voltage you think is necessary. Run Prime95... if it fails, add voltage. If it completes for a long period of time, take away voltage and run again. I'd say you should start at 1.6 and go up or down depending on your Prime95 results.
