ok i wondering what i should do with my front 120mm fan.
orginally it was at the front of the hd bay.
currently i have it set up here
now im wondering should i put it right intfront of the gfx card to help cool it, i tryed and it can fit i just push the harddrive out and i can set it right inffront.
or should i keep it where it is?
or should i put it back where it was originally?
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
also i dont know why but when i turned on my comp my temps where a few degrees lower then usual.
