Hello,
I would be infinitely grateful if any of you SLI pro's out there could help me figure out my SLI problems. I've got Nhancer and Nvidia Control Panel. Nvidia 174.74 beta drivers. Vista Ultimate 64 and SP1.
For the life of me, I can't get only one gpu to engage correctly in Nhancer, for games like Medal of Honor Airborne, where there is no support for SLI or very poor support anyway. If I have SLI engaged in the Nvidia Control Panel (NCP) and try to either uncheck the SLI box in Nhancer, so it's greyed out or check the SLI box and then select single gpu, it still operates under SLI. I've verified this by using the NCP to change to single card (which is time consuming) and playing Airborne with very good results.
I have also tried keeping only a single card engaged in the NCP and in Nhancer keeping the SLI profiles engaged. But then it says in red text that SLI is disabled.
Again any help would be much appreciated. I have many problems so far with SLI, but this is the biggest problem so far. I do not seem to benefit from SLI on any of the games I am running. NWN2 (read every possible forum topic I could find), UT3, and COD4. Any help on those games would also be super.
