Need serious temp help with Q6600
  • Thread starter Deleted member 143938
  • Start date
D
Guest
I have the set up in my sig that I recently got and my Q6600s are very much subpar with my Tuniq Tower 120.
I have the CPU at 3.52GHz (440x8) at 1.43V, and my idle are fine, 28-32C, but under full load they sky rocket to 65-76C with OCCT.
My case is an Antec 300, here is the exact cooling set up:
120mm fan in the back: exhaust
140mm fan in the top: exhaust
120mm fan on side blowing on MB/GPU: intake
120mm top front: intake
120mm top bottom: exhaust (taking out air from HDD and GPU out)
I tried flipping the bottom one to intake, temps were higher by ~3-5C
I tried flipping the side to exhaust, temps were again higher ~2-3C
The Tuniq's fan is facing the same way as the back exhaust.
I know I mounted it just fine because since I got the computer almost two weeks ago, I reseated this Tuniq about 12 times (seriously.. I just can't believe the temp, still) so it can't be a bad seat. I used varying amounts of AS5 during the seatings, and made sure the screws are fully tightened.
I even gone as far as lapping the HSF and CPU last night! :eek:
I did 600-2000 grit on the CPU, it's shiny as.. shiny
I did 400-2000 on the HSF, even more shiny
There was seriously no drop in temps after the lapping, seriously.. maybe 1-2 but I tested the lap at night so ambient temps must have been cooler.
On the ambient temp note, I'm at about 24C roomtemp I would guess.
These temps have to be accurate because I used OCCT, Core Temp and one other program to test, they all matched.
I'm simply clueless, they shouldn't be this high, especially after lapping. I keep reading of Q6600's at 55-62C FULL load on air at 1.4-1.5V, no clue how they do that.
I also have great cable management in the case, there's only one cable (4V to power CPU) that is in between the back exhaust and the CPU fan but I can't do anything about it, it's too short to do anything with and barely reaches the plug. And it's too thin to even make a difference in temps I'm positive.
I'm thinking it's my fan set up, something must be wrong and there's got to be some terrible hotspots inside but I just don't know what to do. Like I said I messed around with the side intake and bottom front fan, but not the others, pretty sure I should have at least the two back as exhaust and one intake at the front.
My GPU is also not hot, 46C idle, and it's at the very bottom of the case with the PSU helping it take heat out, so I don't think it's affecting the CPU.
And my BIOS is configured to run all fans at 100 percent speeds (where possible to change speeds)
Have you flipped the switch on the top and back exhaust up? I have an Antec 300, and they came set on low. Flipped them to medium.
Your OCCT temps aren't that alarming. My Q6600 hits 66C on Intel Burn Test and it's at 8x400 around 1.35ish.
Yup, they're on high.
I don't know, I just keep reading how people at 1.4V+ get 65C TOPS on air at full load
Might just be your chip, some people just get lucky. I just got mine stable at 8x400 @ 1.375 and like I said, burn test hits 60C (case fans all on medium, Xigamtek S1284). So, I think you are right in that range.
Luck of the draw, Some Q6600's are exceptional chips, some are just duds. I wouldn't consider your chip a dud either. 3.52Ghz is nothing to be pissed about. And 65-67c, meh, you're worried about that? My chip needs 1.48v (after vdroop) to hit 3.6Ghz and loads at about 78-82c. It's rock solid stable though, P95 24h and 20 passes of IBT. I run it at 400x8 24/7 though. My chip, or my cooler, doesn't perform that well. I never had a need to run above 3.2 on a daily basis anyways.
It's not the speed I'm worried about... the temp is the matter.
Like I said, I keep reading how 1.4V+ load temps on people's Q6600's are <65C, but mine is at >70
want to trade chips?
At 3ghz my Q6600 is 72-74C load.... then again I got suckered into a B3 from ebay.... however i only paid $120ish for it so im not complaining.
BTW at 1.3v too if I did 1.45v my cpu would prolly fry lol.
You might want to note that the Tuniq Tower is not the best cooler these days and can fairly easily be outmatched. Considering that I would say your temps arn't that bad.
a. how do you deal with the noise?
b. point all your fans towards the cpu... :)
the heat will find a way out... just give it a shot lol..
at 3.6ghz i get 70c... but i only have one fan in my entire case...
At what voltage? I notice you say 1.28V in your sig.
It seems like I'm just going overboard with the voltages.
At 1.40V at 3.48GHz I get 63C max load, at 1.43V at 3.52GHz I get 73-74C, so after 1.4V my heat rises by a lot. I guess I'm OK with 74C for stress testing, it wouldn't get that high under gaming anyway, but over that is just too much.
