Issue 1:
Ok, I just got my swiftech MCW-50 and some tubing and quick connects. How do you connect the tubing to this thing? I bought 3/8" ID and 1/2" ID ClearFlex from Danger Den and both of them wont fit inside the block.
Issue 2:
Now here comes the good part. I was going to use these quick connects with the MCW-50. I couldn't figure out the heck they connect to eachother. So, what I did was, I took the long skinny stem and effortlessly placed it inside the block's connectors. I must of had this in wrong because I couldn't get it back out. So much for quick connects. After two hours of sawing and tugging away with my pliers I finally freed this mess. However, that dark grey part that comes inside the swifttech block had to of been cut, as well as my quick connect, and my finger, and the numerous scratches to the block. Is there any way to replace this small piece of plastic or do I have to buy another GPU block?
I am not happy.
Issue 2:
I am not happy.
