need SATA help
I have an Asus A8n sli deluxe mobo. Now it says this has 4 SATA 3gig adapters. Now i plan to run 2 HDD's in a raid off the SATA. So that's two slots. So does that mean i only have two other devices i can hook up via SATA. Like probably the dvd burner i'm looking at. and one more other device?
I didn't know there were any sata devices out there besides hdd's...¿
It has 8 SATA ports, at least 4 of them are 3Gb. But, currently, what hard drive out there uses 3Gb? There certainly isn't an optical drive that could ever use that.
The deluxe version of the a8n-sli has a total of 8 SATA ports (one device per port). Four are provided by the NForce 4 chipset and support 3gb/sec and NCQ (well, it's supposed to support NCQ, but right now there are serious issues with enabling it). The other four are provided by a Silicon Image controller, it runs @ the slower speed and doesn't (to my knowledge) support NCQ. A word of caution: DO NOT buy a Maxtor Diamondmax 10 series drive for this system, it is known to have serious problems with the Nforce SATA ports with the current bios revision. Other NCQ drives may be a gamble as well, but I don't own any of them so I can't confirm or deny this.
I wouldn't go that far. Yes, some BIOS versions don't work well with these drives and the current nV RAID drivers are not able to exploit NCQ without problems, BUT, currently, the drives do work and work well. Not as well as they can, but very well and better than most. I have stressed them in RAID O and RAID 1 configurations without a problem after disabling NCQ.
When Asus and nVidia update the BIOS and drivers to its expected performance potential (I have no doubt they will), then you will be sorry if you don't have DM10 drives in the machine!
The reason I suggest not getting them is, not only does NCQ not function, but too many people have trouble with the asus board not recognizing their drives after reboot with bios versions after 1002.
