Need rig for under $300
jjolin
just got a new motherboard and i put a sli setup in there, now its running at 50 idle, so i think its time for some watercooling. but there is a catch, i want it to all fit inside my antec p180 since when i sleep my head is like 2 feet away from it, and i leave it on almost constantly, so i want that soundproofing to be put to good use. the only blocks i need are 2 for a 8800gt and one for my q6600. so if you guys could help me out with those blocks, a rad (or 2) and a pump for under $300, id really apreciate it.
you're not going to be able to cool all of that on water internally in a P180, unless you do some serious case modding.
you're looking at at least a 3 or 4 x 120mm rad surface space for all that.
im not sure if u have ebay but this rad fits into you drive bay perfectly and i hear it works just as good as any other after market rad!
Contact him personally I have bought from him before but not his rad, i've read reviews where buers were happy with this persons rad. and if u fit this in ur case with fans then the rest of the components should fit No problem. =)
and his rad mounts are cheap and easy to mount ur rads with!
Heres the link (someone jsut bought one but if u got ebay account u can see the auction)
he has one video card and a q6600, all he needs is one 120mm rad
