Need replacement fan for ZALMAN 9500A
MountainX
I have a ZALMAN 9500A-LED 92mm 2 Ball CPU Cooler in a PC I built in 2006. The fan is starting to make noise. What's my best low-cost option? Can I replace the fan? Is it worth it? Does anyone have links to a replacement fan? Thanks
That's the circular Zalman, right? I doubt if you can replace the fan since it has such a nonstandard mounting method.
