We're proposing a deployment of carrier backhaul chassis that only come in a -48VDC option. The chassis has side A and B input and can alert power failure on either side.
That being said I have next to no experience with rectifiers, but I sort of know what I want.
My director originally spec'd the following Newmar shelf:
http://www.newmartelecom.com/Unity-Rectifier-System/Unity-Rectifier-System.html
I like that it supports a third module for active failover, but the modules connect in parallel to the fuse block, so side A and B output are not tied to separate modules. Therefore if a module fails in the field we have no way of knowing without putting eyes on the install. Also I'd have to supply a separate UPS for backup which I'd prefer to have an all-in-one solution and not rely on another unit.
Having separate side A and B output power isn't as important as a good rectifier, built-in UPS in a 2U form factor and bypass option for swapping batteries. I'll consider all options.
Here's an example of a shelf I'm looking at. The downside is there's only one set of outputs on the rear:
http://www.newmartelecom.com/IPS/IPS.html
Any help from those with experience would be greatly appreciated.
Edit: Input power is 120VAC, Output amps up to ~5
