Need recommendations on small ATX case.
Like the title says, I'm looking for as small possible ATX case. THis is going to be a HTPC build. probably just going to use onboard graphics; so no need for a case to hold a massive gpu.. I'd like as small as possible. but something that will indeed hold an ATX motherboard.
Any suggestions?
Something like this if thermals are not really a big issue (Might not be with onboard GPU)
http://www.amazon.com/Lian-Li-PC-A5...F8&qid=1376419345&sr=8-1&keywords=Lian+li+A55
Another option again if thermals are no problem you could go with a A05FN instead if you need ports in the front.
Another option and this is a newer chassis but looks somewhat compact is the Cooler master N600
http://www.amazon.com/Cooler-Master...1376419829&sr=8-1&keywords=Cooler+master+N600
Or N400
Those offer acceptable thermals for faster systems but are a little bigger. That's just what I thought of off the top of my head hope it helps!
Or N400
that did help. thanks.
CM Elite 361 or Antec VSK-4000 are a bit smaller than both of those.
The Elite 361 might be ideal for you because it's shorter but longer (or something like that); might fit better in an entertainment center than a traditional case would.
Lian Li PC-V650 is the smallest of Lian Li's offerings. PC-V700 is quite small too. They are discontinued recently, but if you look around you can still buy them.
