Need recommendations - Loop routing and drain valve
Nirad9er
I'm in process of getting everything moved into my new Lian Li V2120 and was wondering where I should place a drain valve. The lowest point in my loop is the bottom motherboard barb which I have coming directly from the cpu block so its in a bad spot to add a drain valve due to the short span.
Any recommendations? Should I change the loop around so its more efficient and easier to add a drain valve?
Thanks
