Need Recommendations For Laptop HD
uklegend
I have an ancient Acer Travelmate 250 and am looking for a replacement HD. I don't know much about the current HD (It says "30G Ultra ATA/100 HDD on the sticker on the front), but I want to find a compatible replacement which has both value and performance. I am looking at around 80gb. Can anyone help?
In terms of performance, the Hitachi 7K60 is king of the hill. 7200RPM and 8MB buffer, although it has a somewhat limited maximum capacity of 60GB. It only uses .1 watt more power than a comparable 5400 drive under load, although startup requirements are obviously higher with the higher spindle speed.
Hitachi has solid 5400 drives as well up to 80GB. Seagate and Fujitsu make 100GB drives. If you are looking for a faster drive, I'd settle for, at a minimum, 5400RPM and 8MB buffer. Looking on ZZF, there is a Samsung in the 80GB/5400/8MB category for $123, Seagate for $132, WD for $123, and Htiachi for $133. Seagate owns all of them on the warranty - they're the only maker to offer 5 year warranty on mobile drives.
Thanks for the references.
Does the RPM matter? Also, what does the Ultra ATA/100 signify?
The RPM is basically an indicator of the seek times and media transfer rates. The higher the RPM, the lower the seek times and the higher the transfer rates. That's good. However, the motor has to work harder to keep it spinning that fast, so battery life suffers. Not too badly, the screen is usually the biggest draw, but it's still a factor.
Still, Samsung's 3 year policy is nothing to be ashamed of. I don't think that I'll keep my 2.5" hard drive in constant use three years from now.
So since I tend to keep my laptop plugged in on my desk, could I run a 7200RPM HD with no problems?
Would I need to find a compatible Ultra ATA/100 HD, or could my Acer accept other formats?
I can't speak authoritatively for your laptop, but most likely, your laptop can support any ATA drive in the 2.5" form factor. This includes the 7200 RPM Hitachi TravelStar 7K60 and others, and it includes ATA variations like ATA-100 and ATA-133. It can't, however, support the rare Serial ATA hard drives in the 2.5" form factor.
So I should be ok as long as I steer clear of SATA?
Does attempting to insert a HD void the warranty, say if I was to plug it in and it doesn't work?
:mad:
I meant the standard warranty terms for any new HD. I have only ever bought one before.
I see.
The answer is "possibly." However, you'd be much better off buying from a retailer with a generous return policy. Buy.com has a great return policy because they don't have a restocking fee. That might have changed, or it applies for certain things, but I have bought many things from them because of the return policy.
