Need recommendation
mrgstiffler
Looking to upgrade my speakers.
I only have 2 requirements: optical input, ability to hear speech in video above everything else.
Any recommendations?
Behringer MS40.
That looks pretty decent. I do have room for it, and it's not too expensive. How is the speech in video? I really could give up everything else if I could hear all the dialog in movies. I think whispers should be louder than SFX.
Have you considered using a software EQ to use for your movies? Just increase the midrange a bit and it should help you. What speakers do you have now?
