need recommendation for RAM upgrade please
i currently have 2 512 sticks of OCZ PC3200 Value (OCZ4001024WV3DC-K), the ones with the good chips on them. this is on a dfi lanparty nforce 4 ultra-d and san diego 3700+. i want 2gb of ram. should i grab 2 more 512 sticks of the same ram or do you reccomend 2 1gb sticks of ram. what's really good, pretty decent priced ram that you would reccomend if i went the 2 1gb stick route? thanks in advanced.
Mike
IMO you should (if you can) go dual channel with 1G x 1G, I just upgraded to this and there's a serious boost in performance, it also leaves 2 slots open just incase I ever "need" more :D
2G OCZ Titanium PC3200
infiniti029 said:
ahh thanks i didn't see that, my bad.
i noticed he had a link to these in there
OCZ platinum rev2 pc3200
http://www.newegg.com/Product/Product.asp?Item=N82E16820146899
but they are 512mb sticks, now is this the same ram but in 1gb sticks? i noticed there is no rev2 in the model name so i am thinking its not the same, but anyways is this ram good too?
http://www.newegg.com/Product/Product.asp?Item=N82E16820227210
indeed, before, you could have just been browsing teh intarweb.. more than 512mb is overkill in this case :D
