LGabrielPhoto
- Jan 5, 2006
Hello!
My router is the Cisco Linksys E2500 and it is located upstairs very close to being the room above where the computer (HTPC) is located on my basement. I wouldnt mind getting the best speeds possible but if it gets crazy expensive, I will just with something good enough.
My previous mobo had a wifi built in but the new one I am getting do not, so I need a USB or PCI (not pcie) adapter recommendation for Windows 8.1
Thanks!
Thanks!
