Hey, everyone. I'm trying to select a gaming headset, and I'm having trouble choosing between a few different options. I'm hoping you guys can help.
I've seen the review of the Corsair HS1, and that sounds like a pretty good option. My biggest concern here is the headset's lack of sufficient drivers for true surround. How profound in the difference between a headset with only two drivers and one with more?
I've also looked at the Astrogaming A40s which are attractive both because of the mixamp and because they are wireless. They are not as attractive because of the price, but I could get them if I really wanted. What are the disadvantages of having wireless? I also like that I have the option of using them with the 360 and PS3 although it isn't terribly likely I will do so.
Logitech has some very reasonably priced wireless headsets, but I'm sure I'll have to run some bloated application all the time in order to use them properly. I've also heard Tritton makes a good gaming headset, but I don't know much about them. A quick glance at their site suggests they don't do wireless which would be a plus but isn't a dealbreaker.
I'm looking to use this mostly for gaming on my PC. What do you guys think is the best option for me? Thanks in advance for the recommendations.
