need recomemdation on a Switch.
Nokia
I got 2 computers and one monitor, what switch do you guys recommend I buy? looking for something that works and not too expensive.
thank you for your input.
Not too expensive is relative. If you want to switch VGA there are multiple cheap options.
Switching DVI or Dual Link DVI is more expensive and more limited. Try IO Gear. I use those switches as well as Gefen. The best switches for DVI-D are from Gefen and quite expensive.
