Need reccomendation for Socket 478
Mr_D
Im looking for a nice mobo to fit my current 2.4b northwood and I have looked around but there are so many I though I might ask the opinion of the [H]ard Gawds. My only requirements are that it will let me OC (my current board is an intel so =[ ) and that it supports this ram.
Help please =]
I can't remember if it was Corsair or Kingston's Value Ram, but it wouldn't work on Intel i865PE or i875P chipset based boards. Memory that doesn work in i865PE or i875P chipsets is CRAP. Those chipsets are super common and it's retarded not to validate your ram for the Intel platform. I used that shit in 2 D865PERL's and one P4C800-E Deluxe and the ram never worked properly.
I think it was that Corsair stuff. I remember going to their forums and finding that it wouldn't work worth a damn on Intel based systems. On some motherboards you could do it, but you had to manually set the CAS timings in BIOS.
*F* that ram. I'm sure it would work with some damn VIA chipset based boards, but I personally hate non-intel chipset based boards for P4's.
Not 100% sure that I am thinking of the Corsair, or the Kingston.
As far as motherboard recommendation, you can't go wrong with the P4P800-E Deluxe or the P4C800-E Deluxe.
Abit also has the IC7 and IS7 series that is worth looking at.
I decided to go with the IC7 since I have a audigy and wont be using the onboard sound.
Thanks alot :D
good choice, the ic7 is the best board ( besides the onboard sound ) i've ever owned.
