need rec for CPU C2D and case fan
stevensondrive
I would like to change out the OEM CPU heatsink/fan to something a bit more efficient. and add a 120 fan to the back of the case to pull more air. Quiet is good.
thanks guys
Steve
Scythe Infinity, Thermalright Ultra 120 or Tuniq Tower, to name a few. 'Not sure about noise though since i haven't used them.
Arctic Cooling Freezer 7 Pro for the C2D.....35 bucks and very quiet, good cooling.
Any Sythe 120 mm case fan is a good choice.:D
you must have missed all the 500 different posts recently about neweggs rediculous price for that cooler. every time i login theres another "newegg wants 70$?!?!?!111"
I've never heard of those guys. thanks for the tip.
No problem. Performance-pcs is a great site. They have a shit load of stuff, and some really hard to find spare parts. Their Lian-Li stock is huge.
They will modify almost anything for you. For example, I bought a Lian-Li case and wanted more air flow. The guys enlarged an 80mm hole to a 92mm hole and recommended a Silverstone fan (92 mm fan that fits 80mm screw holes).
They call you on the phone if you have questions.
I usually check there along with frozencpu for most anything cooling or modding rather than newegg.
Do you only shop at one store??????
here's a list of my favourite haunts: performance-pcs,cooler guys,frozencpu,directron,axiontech. look around. the egg's price is way inflated.....just last month the price was 29.95:eek:
here's an example after 20 seconds of searching:http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=185&products_id=3725
I gave your guys a chance. I ordered the fan from them 2 days ago. they just now sent me an email telling me it was out of stock! :mad: WTF!?! it took them 2 days to figure that out??
Newegg just dropped their price to $35. so I'm cancelling the whole order with Ppcs.
:rolleyes:
