need radiator ideas for v2100b
jetjaguar
i will be cooling sli'd 512mb gtxs and a opteron 170
im using a storm cpu block .. prolly maze 4 sli gpu blocks
swiftech 655 pump
my case is a v2100b .. i would prefer not to cut holes but looks like i will
have to ..
which radiator would handle it
An 120.2 radiator such as a Thermochill PA/ BIX2 could handle that amount of heat in the water.
You could mount it to the top panel or the bottom of the case, each will involve modding to some degree though ;)
do u have to cut fan holes on the bottom though if i put it down there .. or can i lay the rad down with the fans on top pulling the fresh air thru the holes already on the bottom ?
It's always best to allow the fans to freely pull air in from outside the case, you'll have to drill a couple of holes to screw the radiator to the bottom anyway.
If you do decide to go for that method, it'd be a good idea to use some non-restrictive air filters - you'll most likely find the fans suck dust/ muck off the floor into the radiator :p
