Need quiet CPU fan recommendation
flwolf
I have an AMD Phenom II X4 955 3.2ghz processor. The retail fan sounds like a vacuum cleaner and is way too loud for the room I am using it in. Can anyone give me a recommendation of a very quiet fan for this processor? I won't be overclocking at all. The PC won't be used hard, either. It's basically a video streaming machine.
Any help is appreciated.
Thanks.
That must be a very old article because every heatsink I looked at is discontinued.
That would be a good one. I am also a fan of the Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler I have used it a couple times & itsproven to be very quiet. As long as you have room since its pretty low profile. you can also change to a thicker 120mm fan later if you want some more airflow & no more noise (can with most, but there is a little more variety available then 100mm)
Any heatsink that utilizes a 120mm fan will be pretty quiet; it just depends on your budget.
You know over on the main site they have some heatsink roundups right?
