need quick answer please.
the monitor that your asking about has only a 15 inch screen which is small in todays world and the resolution that it displays is only 1024x768 which is'nt that good, I'd say spend a little more money and get a bigger LCD or use the same money and get a really good CRT (normal) monitor probably a 19 inch size. Hope that helps
thanks. the small size doesnt bother me cause i have a crt for home, and this would mainly be used as a lan monitor. i play all my games at that resolution anyways so i wasnt bothered by that. im more worried about ghosting and shadowing etc. thanks though,
thanks i think ill just wait it out until i have enough for a better one. thanks.
