Mackintire
- Jun 28, 2004
So I want to define QOS for three EGRESS routes.
The first flow is from ANY to a specific IP
The second flow is from ANY to a different specific IP
The third flow is from ANY to everywhere not defined about
I believe that should use the minimum guaranteed bandwidth feature via CIR for this.
So first....
Can I apply a CIR QOS to the default Egress route
What would be the proper syntax for this?
Once I have that working can you check my other flows syntax?
Thanks,
Mackintire
So first....
Thanks,
Mackintire
