Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Black wires are ground. Yellow is +12V, red is +5V, orange is +3.3V, purple is +5VSB, blue is -12V (you don't need to bother with it), and green is PS_ON. Connect the PSU to the wall and leave the switch in the off position. Use something conductive like a piece of wire or a metal paper clip and connect the PS_ON wire to one of the grounds. Flip the switch and the PSU should start up. Then you can measure each of the voltages. They should all be within 5% of their nominal values, which means that the +12V should be between 11.4V and 12.6V, +5V and +5VSB should be between 4.75V and 5.25V, and +3.3V should be between 3.135V and 3.465V.
