I'm looking to build a new desktop, but I'm not sure what kind of wattage I need, or what ones to look for. Here's what I'm planning:
Intel P965 mobo, hopefully the DFI P965-S if it comes in stock
Core 2 Duo E6600
2GB RAM
2 SATA 400-500GB HDs
1 DVD Burner
for the video card I'm planning on getting something when R600 is released, or I may just go with the 8800GTS 640MB.
I'm also planning on OCing it pretty high, probably with a Thermalright Ultra-120 Heatsink.
I was thinking that 550W may work, but I'm not sure. I want to have room to be able to use something like an 8800GTX if I want. I'm not concerned about powering SLI. I'd also like to stay around $100 if possible. Thanks for the input.
I found a Hiper 580W at newegg for $90. It gets good reviews there, but it's not a super well-known brand. I like the modular cables that it has, and the price is nice, but I don't want to get something that isn't enough for my system, or that I may have to replace down the road.
I also found the OCZ GameXStream 700W PSU at ZZF for $100 AR. It gets great reviews as well, but doesn't have the modular cables. Does anybody have any insight on this PSU?
Core 2 Duo E6600
2GB RAM
1 DVD Burner
