need printer help
amit77
need printer help
have an old computer that only has parallel ports, no USB..
all printers are now USB
need a place to find a parallel port CHEAP printer
or a cable to convert..
help
They make converter cables, but they are a generally bad idea. Most require drivers since the cable actually has to convert from a serial to parallel format. I don't know where you can find a cheap parallel, as most printers that have parallel these days are the nicer ones, which maintain bacward compatibility by having both ports.
there are PCI cards that have 4-6 USB ports on them. sold at most computer stores ie. best buy, comp usa, fry's electronics.
the computer is for business, it runs DOS only..i imagine driver installation would be tough?
