Alright, I haven't built a new comp in a few years, and I haven't been able to keep up with which parts are preferred to others.. Basically, I'm looking for a mid-range gaming system, target price of about $1000-$1500.. I'm going to be building 2 of these.. One for myself and one for my dad, so some parts will be reused from our current comps. His is for gaming. I do a lot of gaming as well as some digital art/photography work..
Basically, I'm looking for a decent build, not too cheap (I want high quality parts), but I don't need top of the line parts that are 2x the cost for a minor speed increase either.
As far as the proc goes, I'm thinking about one of these 3:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115028
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
I'm really not sure which one to go with. Is the price difference between the E6600 and the others worth it, or should I go with the E6600? Also, is the quad core worth the price, or should I go with the 6850? I really just don't know how to choose which would be best. I'm currently leaning toward the Q6600 or E6850. Also, I know Penyrn is released soon, would it be a benefit to wait or will prices not really change? (prices on the procs I have listed).
I also need a good motherboard suggestion for any of those. I'm not really sure which features I need. I'm not planning on OCing. Also, I'm not sure what type of CPU cooler I need. I'd like to keep the comps as quiet as possible, but I'm not looking to overspend on silent parts.
For RAM, I'm guessing I should look into DDR2.. But I'm not sure which manufacturer to look into, or what speed would be best. Is 2gb enough or should I get more? I'm mostly looking to be playing games on the level of CoD4 now, but I'd like to have a system that will play newer games that haven't came out yet at decent quality settings well.
I could also use a suggestion on a decent video card. I started looking into a new system about a month to 1.5 months ago. I think the 8800GT was the card to go for at that time for price/performance value. Is this still true or should I look into a better card? It seems that price gap between the 8800GT and the next step up has closed up a bit from what I remember.
Anyway, I think that is all I need for now. Just need some clearer info on what core system parts would be best for my needs. I appreciate any help!
