Need opinions please...(VIDEO CARD)
nodle
Ok I think I may have screwed up. I have just ordered a new motherboard (ASUS A8N-SLI Premium) Anyways, I also ordered this card with it. LINK
Now I wasn't planning on playing games with it, but today I thought that I may want to start playing games. I have been out of the loop with video cards for a little while now, so I need some recommendations On a new video card. I plan on ordering this tonight so it can be on its way. My budget is around $150. Do I go ATI or NVIDIA? I would like to be able to play games like Half-life 2, Counter-strike, Serious Sam 2 etc... Without problems. What card would you recommend off of Newegg? Whats the best bang for the buck right now? I dont plan on overclocking it either. Oh one more thing, I was trying to keep the noise level down to a minimum, thats why I original went with the XFX card. Thanks for all the help with this guys!
What games do you want to play? You bough a SLI motherboard,so i assume the latest. if i were you, i would return that 6200 and go for a 6800 with you $150.
nodle said:
What do you guys think about this one? http://www.newegg.com/Product/Product.asp?Item=N82E16814161146 Im trying to go with as quiet as possible...
You need an Nvidia card. Nvidia is what you should be looking for since your have one of the the best boards that does very good in SLI. Buying an ATI card would make no sense.
I recommend the 6800gs. Yes it's $200, but so is that x800gto. And this is better because if you ever need more power, you could just add on another card.
http://www.newegg.com/Product/Produ...0&MaxPrice=250&SubCategory=48&Submit=Property
i would also recomend the 6800GS, nice card, and nice clock speeds too! :D But if you cant quite afford that, or dont want to wait another 1-4 weeks before you get the money, then i would recomend one of the higher-end 6600GTs, such as THIS
~Hope this Helps!~
