Need opinions on new setup
fdexclpl
I am putting a watercooling setup together in the next month or two. I have been doing some research and I came up with list of what I think I need.
TDX Water Block
Black Ice Extreme Radiator
Hydor L35 pump
10' Clear Flex tubing
5 1/4" bay resevoir
4oz of Zerex
Hose clamps and fittings
I already have a 120mm fan and AS Ceramique compound.
This will be going into an Antec Sonata case. I also have an Antec 1040B case that I could use. Any opinions or suggestions?
Thanks.
Oops I forgot system specs!
A64 3200
MSI K8N Neo 2
Looks good. But if you aren't going to have any other water blocks in the loop you might want to think about the RBX instead. It gives better performance and costs less.
I can also suggest Tygon over the Clearflex. My Clearfles had that white build-up on the inside and and I run distilled water and Hydrex. The Tygon did not have that problem. Keep the tubing runs short and clean like this:
