Need opinions on case airflow
DaLurker
My case is an Antec SX1200. It's a full tower case, and the lower portion of the case is like any Antec case out there, it just happens to be taller, so imagine a normal antec mid tower case (such as the SOHO cases), with an extra 2 drive bays up top (out the back, there's a 92mm Fan slot above the PSU).
Now I have watercooling (Switech 5.25" Res, Switech MCW-6002A, Switech MCP-650, 77' Bonneville Heatercore) where the heatercore is mounted on the roof panel with 2x120mm Vantec Stealth fans pulling air out of the case.
Now my situation is with my pump and wire routing, I've essentially segregated the bottom from the top in terms of air flow. Now on the lower parts, I have 3 80mm Intake, 2 80mm Exhaust, and of course my PSU fans exhausting. SO the bottom part is fine.
Up top however, I have the 2 120mm Exhasuting, but only 1 92mm Fan intaking, so clearly I have too many exhaust, and not enough intake. Right now, my temps are fine, and there seems to be enough air coming out the fans (although there was a more air coming out when I had all the 80's on intake).
I'm thinking to fix this problem, I can make two 120mm Blowholes on the side panel to so the 120mm's have a source of fresh air to pull air in, and as a bonus, it would be cool ambient air blowing through the heatercore, instead of heated case air suctioned up from the bottom of the case).
What do you guys think?
Well I went ahead and cut a blowhole out the side, and it seems to be doing well. Dropped my temps 2-3 degrees :D
