Dapperdan
- Jun 17, 2002
This is my setup, the i7 920- P6T deluxe- Noctua NH-U12P- CORSAIR Dominator 6GB DDR3 1600- Vista 64.
Original
OC
Numbers:
CPU Ratio: 20
BCLK: 190
PCIE: 100
DRAM Freq: DDR3 - 1523 MHz
DRAM Bus: 1.66
CPU Voltage: 1.35
CPU PLL Voltage: 1.96
QPI/DRAM Core Voltage: 1.35
CPU Differential Amplitude: 800MV
When I run Prime95 it goes to blue screen after a few mins. Speedfan shows all the cores with the flames when prime95 starts up then get a BSOD. Not sure what to do.
Original
OC
Numbers:
CPU Ratio: 20
BCLK: 190
PCIE: 100
DRAM Bus: 1.66
CPU Voltage: 1.35
