I currently have an Antec true430
My small problem is the 3.3v rail is averaging 3.22V and dips down to 3.09ish V under heavy load and heavy overclock, (my sig) I think this is causing some instability when it drops too far and my system reboots occasionally.
I need a 2nd psu for my old rig parts so I can run both systems.
so I might as well get a new psu for this overclocking rig.
my two choices are:
ENERMAX 460W Power Supply for AMD K7 & Pentium4, Meet AMD K7 and Intel ATX +12V 1.1 and ATX 2.03 version, Model "EG465AX-VE (W)FCA"
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-432&depa=0
Output: +3.3V@35A; +5V@35A; -5V@1A; +12V@33A; -12V@1A; +5VSB@2.2A
OR
Antec 550 Watt Power Supply With 2 Fans 5.25 Control Panel, Model "TRUE CONTROL 550W" -RETAIL-
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-922&depa=0
Output: +3.3V@32A; +5V@40A; -5V@0.5A; +12V@24A; -12V@1A; +5VSB@2A
The prices are about the same.
what would everyone else chose? the enermax has less wattage but higher 3.3V amperage and 12V
yet the antex is higher watter with higher 5V rails.
my two choices are:
OR
