DanThePlanMan
- Jun 7, 2004
Spec's
VapoChill XE, P4 3.4C @ 4 GHz, Abit IC7-G (DD water block), 2x512 Geil PC4000, ATi X800XT (DD water block), (2)-WD 80GB SATA HD's @ Raid 0, NEC 16X DVD Burner, DD 12V-D4 pump, (2)-120mm 100cfm fans,Fortron 530watt P/S (DD = Danger Den)
Everythings been working great. However I just got a PC AirCon PAC 400. This is a PC Air Conditioner that works off a Peltier. It's rated at 53 watts. When the computer is just sitting there running the PC AirCon works pretty good. It's lowering the case temp by 4-6 degree. But it's causing ramdom shutdowns. It might work fine for 15 minutes or it might work for 2 hours (when in use), but sooner or later it will just quit (when in use). This wasn't happening before so I'm sure I need a bigger and/or better P/S. Any and all recommdations are welcome. Some review links would be helpful also.
Pretty is ok but Performance is the biggy. I can spend up to $200.
