need new mobo, any ideas
el_lance_o
k I gots right now an albatron kx18 d pro and it was good for a while, but recently it's been acting so ghetto I can't stand it. I leave my video card clocked at regular stock speeds, and all my games freeze for no reason. Also, I can't overclock it high at all and I'm using a mobile 2500 too. My system used to be stable with my 33 ram at 2.4 ghz, and now it just won't do that anymore. Anyways, I'm gonna get a new motherboard now, and have a few in mind. Here are there names:
Abit nf7-s nforce 2 version
Dfi lanparty nfII ultra B
gigabyte ga-7n400 pro2
abit an7
dfi nfII ultra infinity
soltek sl-75frn2-L
AOpen AK79D-400VN
Or any others I should get if it's better, but this is my list right now. Also, I'm not trying to spend a lot of money for one if I don't need to and erformance isn't that much better. Kinda on a budget also
I personnally would go for the DFI infinity, its one of the best OC boards out there, but it hasent got all the nice,but price upping stuff of the lanparty and abit boards (Dual NIC , rounded cables included, a carrying bag)
id go with the dfi too but if your on a tight tight budget get a albatron kx-18D, it ocs pretty well, i got my mobile 2600+ up to 2.6ghz at 52c full load and 42c at normal usage with my ttake blower hsf and runs really really stable but im scared to keep it OCed now because i think it might not be that good since its a brand new mobo so its stock now.(it has the nforce2 ultra 400 chipset). but i think a DFI would be better, my friend has one with his mobile 2600+ watercooled and it runs at 2.7-8ghz stable(yes amazing :D )
yeah I got the albatron one right now and haven't been very happy with it, so I need a new one anyways, I believe that's the source of all my freezing and such, so I'll check into the dfi one. Or howbout that soltek one, I read a review saying that that was a really great board too.
... or should I keep my processor at it's regular speed for now and invest in getting a geforce 6800 or 6600gt( depending on whatever amount of money I have by then), would that be a better investment
I am afraid the processor at stock speeds will be a bottleneck for those GPU's
So you are in a shitty situation
1. New vcard - Not performing at its full potential
2. New mobo - CPU speeds are up but maybe the Graphics card u have now is a bottleneck to that speed.
k, I got a 5900xt right now. Also, I have a gig of dual channel ram in there. I might and should be able to hit 2.25 ghz or maybe even 2.4 if I figure out how I did it again. If I could get that then would it just be worth while to get the video card instead? I got no idea which way I should go
How have you determined that your current situation is being caused by your motherboard, and not one of your other components such as your power supply. Around when could you do all that overclocking, and how long has it ceased to do so?
I always place my votes for Shuttle's AN35N Ultra for a cheap replacement and the A7N8X-Dlx for high end replacement (I've got them both.)
I have a thermaltake true power 480watt psu. You do have a point that it could not be my motherboard, and yet another component, or maybe it's getting too hot. I kindafigured that it had to be my board because when I tryed going for 2.25 ghz, I loaded up ut2k4, and it froze its ass off, so I have some to the conclusion that it has to be the motherboard. Great now I don't know what would be the best thing. Either get a new board, save up for a geforce 6600gt, or get an athlon 64 2800 w/ mobo for about 230 bucks. What do ya think I should do, cause If I just get the video card, my system is running pretty fast right now as it is with my setup.
