need motherboard & memory advice
gbrown
I'm about to build a new machine and I'm trying to decide on a couple of things. First let me say my goal is to have as stable a machine as possible, I will most likely not overclock. I've been trying to narrow it down to one of these motherboards:
Abit IS7 $95.99 Asus P4P800 Deluxe $125.00
Abit IC7 $119.99 Asus P4C800 Deluxe $169.99
I'm leaning towards the IC7, but would like more opinions on these boards. As far as memory, it seems there are many more choices now that the last time I built a computer (1999). Should this get the most out of the machine at stock speeds? (going with P4 3.0C)
Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 - Retail
Specification
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-3-3-6 T1
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: With Platinum Heat Sprea
Thanks for any replies.
The speed difference between the two is negligible, if any.
People seem to love their 875s (like the IC7) but my experiences weren't as good as they were with the 865. Not talking performance, just stability and compatibility.
Either way, they're both quality boards and you shouldn't be disappointed either one you choose.
Just remember that that IS7 for only $96 comes with LAN and the IC7 doesn't. You'll have to get the $150 IC7-G or the $192 IC7-MAX3 for that.
Comparing the regular IS7 to the IC7-G, the price difference is $54, and all you gain really feature-wise is instead of just 2 SATA RAID ports and 2 SATA Ports, those other two SATA Ports are RAID as well.
O yeah, and that memory is the stuff to get. Corsair XMS is great.
i would say that since you arent overclocking at all then the only other things to look for with those motherboards are some of the options. are you going to use SATA, how many USB ports you will want, do you use firewire just pay attention to those little details and you should be able to find the right motherboard for you. as for me i went with the P4C800-E Deluxe board and i havent had a single problem with it.just make sure to flash the BIOS before you install any kind of operating system on it first. but ive read a lot of good reviews about all the boards you have listed so i bet that whatever one you choose you will have good fortune with it :D
My dad never was big on overclocking... I have a Pentium 3 750MHrz. Currently running @ 750MHrz. I don't want the thing to overheat, so it will stay at that speed!
You'd be surprised what you can overclock to without any increase in heat. My 3.06 is at 3.45 and there was no significant increase in heat at all. My 2.0A is the same way. 2.65 no increase in heat under load. Stock air cooling on both too.
Well, I just overclocked my video card a bit earlier, using the program RivaTuner. I HAVE noticed a large difference when playing SWG (Star Wars Galaxies)! This game is VERY computer resource intensive, and overclocking my video just a little bit (better safe than have to cough up a hundred bucks), created a slight increase in performance! I haven't noticed any unstability yet either.
