Need more power
sinplicity
ok I used clock gen and got my pc to 2.2 is there anything else I can do to get her higher?
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Name AMD Athlon 64 X2
Code Name Manchester
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Family / Model / Stepping F B 1
Extended Family / Model F 2B
Brand ID 5
Package Socket 939
Core Stepping SH9-E4
Technology 0.09 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
CPU Clock Speed 2200.0 MHz
Clock multiplier x 10.0
Front Side Bus Frequency 220.0 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2200.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
CPU#2 APIC ID = 1
Brand ID 5
Package Socket 939
Technology 0.09 µ
L2 Location On Chip
Mainboard and chipset
Motherboard manufacturer
Motherboard model MS-7093,
BIOS vendor Phoenix Technologies, LTD
BIOS revision 6.00 PG
BIOS release date 07/21/2005
Chipset ATI Radeon RS480 rev. 00
Southbridge ATI SB400 rev. 00
Memory
DRAM Type DDR-SDRAM
DRAM Size 2048 MBytes
DRAM Frequency 220.0 MHz
FSB:DRAM CPU/10
CAS# Latency 2.5 clocks
RAS# Precharge 2 clocks
Cycle Time (TRAS) 8 clocks
Bank Cycle Time (TRC) 12 clocks
DRAM Idle Timer 16 clocks
# of memory modules 2
Module 0 DDR-SDRAM PC3200 - 1024 MBytes
Module 1 DDR-SDRAM PC3200 - 1024 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
sorry i wasn't more specific here. 2.2 is clock gens max. Is there another program i should be using. My bios is very limited with this board.
yes it is the MSI, and that is what I was hoping not to hear. Ok so has anyone been able to OC the MSI K8NGM2-FID Socket 939 NVIDIA GeForce 6150 Micro ATX AMD Motherboard? if not what else do you suggest. Thanks
hm... it's probably your processor holding you back then, since the msi board can do 250fsb stable, but it can't change the vcore, which is whats most likely holding u back. if you want a new board that oc's well, get the foxconn 6150/430, does 275fsb stable and has vcore and vdimm adjustments, which is plenty for ur processor.
