Need mobo expertize
This is my first time building a computer so yeah I'm a n00b. Here's my dilemma: I have the new Intel 45nm Yorkfield QX9650 and I need a motherboard that is fitting for such a beastly cpu (thus having a BIOS that is compatible with 1333 fs bus). I intend to use this computer for gaming and casual use, but most of all, I intend to play Crysis so I want a b*tchin' mobo and graphics card. I desperately need some mobo suggestions!:(
If you can afford the QX9650, I'm sure that you can afford the Maximus Formula too.
Thanks for helping a n00b out. I had heard about the new ASUS Maximum Formula motherboard but I didn't have the time to do any research on it. Is that really the best mobo for my cpu because I don't want to be having problems with the BIOS?
Unless you want to waste your money an DDR3 RAM, I'm pretty sure that the Maximus Formula is one of the best mobo out there but the price is quite expensive.
I looked up the mobo and did my research on it and I found out that that motherboard (ASUS Maximus Formula) had serious problems with the BIOS. I also found out that despite ASUS's attempts to fix it up with a patch, the BIOS problem still remains. What now? The mobo looks promising but I need to know for sure if its worth getting.
:( HELP!!!!:confused:
What problem? With 45nm CPUs?
I read the reviews from people who commented about the mobo. Here's the link: http://www.newegg.com/Product/Produ...ing=1&PurchaseMark=&VideoOnlyMark=False&Page=
Plus, they said that the board will overheat the processor and I'm not going to risk messing up my QX9650. Also, this board supposedly eats up RAM too. I need a board that is compatible with Windows XP and can still operate great with my sick cpu too. I know that it is a little too specific but I really don't think that Vista is worth getting so that's why the mobo is so hard for me to choose.
The Maximus Extreme or Maximus Formula are the way to go without a doubt. Anything less is unfitting for such a CPU.
I've used that board extensively. I never had any problems with it. I'll tell you this: If I didn't want to continue to use SLI so badly, I'd be using the Maximus Formula and no other board. It is the only board I've touched in quite some time that I'd use in my own machine.
Are you guys sure? I trust you guys with this. So I should just disregaurd those morons who said that the board would overheat my processor? Maybe it would help if I show you my case. Here it is: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&Tpk=antec+nine+hundred
Do you think that it has any chance of overheating as easily as they say? Also, what about the whole problem with the mobo eating up the RAM?
P.s. I really appreciate you guys helping me out! :D
It is 680i SLI boards that eat RAM. I've never heard of any X38 chipset based board doing that. Your case is fine. I'd advise you to consider several sources when purchasing a motherboard but in my experience the Maximus Formula and Maximus Extreme are excellent boards. Also realize that while you'll find horror stories on the web most of the time those people posting those horror stories either don't know what they are doing or they are in the minority.
If they overvolt their CPU, it will overheat the CPU. I guess that they are using the stock cooler and OC their CPU without any knowledge at all. I'm using the Maximus Formula myself without any problem.
However there are reports of a problem with the BIOS, it is not the board is overheating the CPU but the board is reading a higher temp with newer BIOS than older BIOS. Not a real problem actually because it is safer to have a higher reading than a lower reading.
I've been shopping around and researching mobo's for the past 3 months just trying to find the perfect motherboard for me and to no avail. Dan_D was able to help me in a matter of 1/2 an hour. Many thanks Dan! :D
..... God. I wish that I could have all that lost time back. :( lol!
So you're saying the 1200W power supply that I was thinking of getting is a bad idea and that it would overheat my cpu?
Why do you think you need a 1200watt PSU? What brand were you looking at? As for overheating your CPU, it won't. A PSU will only output the amount of energy that is being drawn from it. So if you have a 1200watt PSU and only 800watts is being pulled by your hardware, the PSU won't output anymore than is required. Therefore 800watts is what it will out put. I don't actually need a 1200watt PSU. I could get by with a solid 850 or a 1kw unit. Your rig won't likely require anywhere near the power mine does. So 1200watts seems like a waste. I advocate buying something that leaves you room to grow, but you don't need to double the wattage and deal with abnormally large PSUs when you don't have to. The 1kw+ units are generally larger than most ATX cases can handle. You need to keep this in mind when PSU shopping.
As for reviews, I hadn't realized that you were reading Newegg reviews. You can ignore those. Those are generally written by morons who have no idea what they are talking about.
Oh okay. I was looking at a Thermaltake. Here's the link: http://www.newegg.com/Product/Produ...tion=thermaltake+power+supply&Ntk=all&bop=And
I know that this isn't the right thread for this topic, but do you think that you could find me a good power supply because between my graphics card and my cpu, I thought that bigger was better?
That's the PSU I have. Bigger isn't always better. That's a good PSU but you can probably find something cheaper that will fit your needs just as well. Beyond that the PSU in question is way too large for most cases. I don't know if there is room in the Antec 900 for it or not.
It does look a little bulky, but the antec nine hundred is pretty big too. I just measured the psu slot on the antec and it was approximately 6.5 inches long , 3.5 inches wide, and about 7 inches diagonally. A little too specific? I don't know. I'm a freakin' loser n00b! lol!
Anyway do you think that the power supply is too big?
That's not enough room for a Thermaltake Toughpower 1200watt. The Thermaltake 1200watt is 9 inches long and that doesn't even leave room for the wires.
The only reason you would EVER need a 1200w PSU is Tri-SLI. Just get a 600-700w and be done with it. The Corsair 620w or 750w would be perfect for you.
Well for a dual SLI setup for the higher end cards I'd still go with an 850 watt unit from a quality manufacturer. I've checked my rig running two cards at full load and it was drawing somewhere in the upper 600 watt range. I'd prefer to have some padding myself and not tax the unit. Though I've seen some pretty serious machines run successfuly on sub 700watt PSUs, I don't recommend it.
Ah, but SLI was only mentioned in replies, not the original poster. Frankly, I assumed he wouldn't be running SLI, since he said he was looking for a motherboard and *A* graphics card.
I agree. That's why I started telling him that he didn't need a 1200 watt PSU.
dont you kind of want to get your stuff and put it together? seems like you have been "thinking" about it pretty long. there are several solid x38 boards out there that run 45nm cpu's fine. there is even a x48 board or 2 available (msi plat). get a 700 or 800 wat psu by silverstone, seasonic, corsair, etasis or tagan. this thing has 6 20 amp 12v rails, flashes in about 5 colors, comes with a carrying case, gloves, tools, a gasket, enough connectors to hook up a small town for $170 ar http://www.newegg.com/Product/Product.aspx?Item=N82E16817814014. get moving.
That PSU looks great vanilla. I've been eye-ballin' that one for a while now but I'm just a little weary as to if I should buy it and if it would fit in my Antec Nine Hundred.
You guys might already have guessed but I really do my research and shop around for this stuff because I want to get the best for my hard earned cash. Any other suggestions?
Also, I need help with mobo expertise in another project of mine. Please help!
